Change the interface type to designate the interface as either passive, NBMA, or broadcast.
  • Enable OSPF globally.
  • Ensure that the interface uses an IP address.
  • If the interface is currently an NBMA interface with manually configured neighbors, you must first delete all manually configured neighbors.
  • Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select OSPF.
  3. Select the Interfaces tab.
  4. To disable the interface, double-click the AdminStat cell, and then select disabled.
  5. Select Apply.
  6. To change the interface type, double-click the Type cell, and then choose the new interface type.
  7. Select Apply.
  8. To enable the interface, double-click the AdminStat cell, and then select enabled.
  9. Select Apply.
